[Qgis-user] Re: QGIS Server Ubuntu 11.04 GetCapabilities not showing layers
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Thu May 3 01:41:52 PDT 2012
Hi
I think the problem is that QGIS server cannot find the QGIS libraries
(because they are not in a standard location).
To change this, adapt your /etc/apache2/mods-available/fcgid.conf file
with 'FcgidInitialEnv LD_LIBRARY_PATH'.
As an example, here is my fcgid.conf file (with the QGIS libraries under
/home/marco/src/Quantum-GIS/lib):
<IfModule mod_fcgid.c>
AddHandler fcgid-script .fcgi
FcgidIOTimeout 200
SocketPath /var/lib/apache2/fcgid/sock
FcgidInitialEnv QGIS_LOG_FILE /tmp/qgisserver.txt
FcgidInitialEnv LD_LIBRARY_PATH /home/marco/src/Quantum-GIS/lib
FcgidMaxProcessesPerClass 16
FcgidMinProcessesPerClass 16
</IfModule>
Regards,
Marco
Am 03.05.2012 10:35, schrieb bboughton:
> I have tried opening up permissions on the test.qgs file as per:
> http://gis.stackexchange.com/questions/14806/qgis-server-capabilities-response-doesnt-contain-any-layers
> with no results. I have subscribed to SE but cannot yet respond to this
> question without answering it in order to 'bump' or refresh it. Is there a
> way to confirm that the server can reach the shape files?
> Should I try going back to an even older version of Ubuntu or even Fedora?
> Alternatively, I am considering trying GeoServer and Mapbender using uDig to
> create my layer files. QGIS Server seems so much simpler if I could just get
> it going. Thanks.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/QGIS-Server-Ubuntu-11-04-GetCapabilities-not-showing-layers-tp4945055p4948711.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole - Linux& Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
