[Qgis-user] polylines to single lines
Victor Olaya
volayaf at gmail.com
Tue May 8 03:03:17 PDT 2012
Piotr
I have just uploaded a new version of the plugin (1.0.5) It contains
the "explode lines layer" algorithm (search for it using the search
box on top of the SEXTANTE toolbox). Hope you find it useful
Regards
2012/5/8 Piotr Pachół <piotrpachol at gmail.com>:
> Yes, I mean exploding polylines to line segments only with starting and
> ending point.
> Piotr
> W dniu 2012-05-08 01:03, Victor Olaya pisze:
>> you mean to segments with just an end point and a starting point?
>> That should be easy to do and a good addition to SEXTANTE :-)
>> Regards
>> 2012/5/8 Piotr Pachół<piotrpachol at gmail.com>:
>>> Hello,
>>> Is it possible in Qgis or in Sextante plugin to convert line layer with
>>> polylines to simple single lines ?
>>> It should work as cad command "explode".
>>> If not may be it would be usefull to add new option (checkbox) in command
>>> "Multipart to singlepart".
>>> Regards,
>>> Piotr
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
