[Qgis-user] Sextante: setting the output folder
Paulo van Breugel p.vanbreugel at gmail.com
Tue May 8 07:12:33 PDT 2012
There was no such conf file in the folder initially. Only when changing
some other settings (e.g., in GRASS GIS settings) the file is created.
In a new session, these GRASS settings are maintained. Also, if I now
change the folder location in the general settings, this is maintained
in the general settings too. Meaning, if you open the options, the new
path is there and also in the conf file, the new path is there.
However, Sextante does not seem to do anything with that path, it keeps
using the default folder (user/sextante).
Cheers,
Paulo
On 05/08/2012 10:47 AM, Victor Olaya wrote:
> is in the config file at [your user
> folder]/sextante/sextante_qgis.conf, at an entry named OUTPUT_FOLDER
> Regards
> 2012/5/8 Paulo van Breugel<p.vanbreugel at gmail.com>:
>> This is the only one I encountered so far. But I will test a bit more. Where
>> is that folder location definition stored? Maybe I can change it there?
>> On May 7, 2012 9:21 PM, "Victor Olaya"<volayaf at gmail.com>  wrote:
>>> I cannot replicate the bug...it seems to work for me. Does it happens
>>> with other parameters or just with this one?
>>> Regards
>>> 2012/5/7 Victor Olaya<volayaf at gmail.com>:
>>>> That looks like a bug. I will have a look at it. Do the other settings
>>>> remain between different sessions, or they are lost as well?
>>>> Thanks
>>>> Victor
>>>> 2012/5/7 Paulo van Breugel<p.vanbreugel at gmail.com>:
>>>>> Hi,
>>>>> I am trying to change the sextante folder location by changing the
>>>>> path/name
>>>>> of the Output folder in the Sextante options. However, after closing
>>>>> and
>>>>> opening QGIS, the Output folder is set back to the default (sextante
>>>>> folder
>>>>> in the home folder). Anyway to do this differently?
>>>>> Rgds,
>>>>> Paulo
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120508/ddcaf58e/attachment.html>
