[Qgis-user] Handling of GRASS console outputs in Sextante
Paulo van Breugel
p.vanbreugel at gmail.com
Tue May 8 07:17:54 PDT 2012
How does Sextante handle GRASS modules that output their results to the
console. An example, the (default) output of v.report is a table send to
the console. And this is what happens too when using the module in
Sextante judged by the batch script created by Sextante when running
v.report.
This is not very useful because the user is not running this from the
console (or more correctly, this process is hidden for the user), i.e.,
no result is presented to the user. Sextante should somehow capture the
output and present it to the user (which is not happening now it seems).
There are various GRASS functions which output is send to the console
(normally it is possible to send the output to a text file, maybe that
can be used by Sextante?).
Rgds
Paulo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120508/d2449ab5/attachment.html>
