[Qgis-user] Sextante: setting the output folder
Paulo van Breugel
p.vanbreugel at gmail.com
Tue May 8 12:09:00 PDT 2012
Thanks for the reply and your explanation, yes, it makes things clearer,
thanks.
What I tried to do is to change the location of the 'Sextante' folder.
This is now automatically created in my home folder each time I start up
QGIS (if it isn't already there). I would like to have that folder in
another location that better fits how I organize my folders.
I though I could change that in the general settings, but I think I
misunderstood that option. Does this mean the location of the folder
sextante is 'hard coded' somewhere as 'home/sextante'? If so, is there a
way I can change that? I hope my question makes sense, otherwise, I
might not have understood things completely after all :-/
Cheers,
Paulo
On 05/08/2012 07:23 PM, Victor Olaya wrote:
>> There was no such conf file in the folder initially. Only when changing some
>> other settings (e.g., in GRASS GIS settings) the file is created.
> If you do not change anything, the file isnot created, since it uses
> the default values
>> However, Sextante does not seem to do anything with that path, it keeps
>> using the default folder (user/sextante).
> what do you mean with "it keeps using". If you enter a filename like
> "myraster.tif" (without a full path), it will save it to [output
> folder]/myraster.tif
> That is how the output folder works, and as far as I can tell, is
> working fine in the latest version.
> If you click on the button on the right of the selection panel, it
> will open the default folder, but only if you haven't used it before.
> otherwise, it will open the file selection fialog in the last folder
> that you used.
> If you do not enter any filename, the output goes to a temporary file,
> and those files are always kept in user/sextante/tempdata, since it is
> assumed that are temporary and should be deleted. Otherwise, you
> should have entered a full pathname or at least a filename.
> Hope this makes things a bit clearer
> Regards
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120508/7f0076bd/attachment.html>
