[Qgis-user] Re: Default QGIS template for Windows users
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Fri May 11 01:14:51 PDT 2012
Not all, or lets better say, nearly no Windows user really knows what the
registry is and what to do there without crashing the system, so answers
like "look in the registry" are not really helpful!
The disappearance of toolbars is a quite common problem in qgis.
I found
http://osgeo-org.1560.n6.nabble.com/toolbars-which-are-moved-are-away-td4476255.html
where is said, that you have to remove
\HKEY_CURRENT_USER\Software\QuantumGIS\qgis\UI\state
in the registry.
When you restart qgis, the key is written again with the default state,
and all toolbars are visible again.
> 1. Re: Default QGIS template for Windows users (Goyo)
> 2012/5/10 William G. Guthe <wguthe at princeton.edu>:
>> The Map Navigation toolbar has disappeared from my QGIS 1.7.4. Â The
>> toolbar
>> can be turned on and off under View -> Toolbars, but nothing changes in
>> the
>> GUI. Logged into the same machine as a different user, the toolbar
>> appears
>> and can be managed under View -> Toolbars.
>> I assume there’s a modified default .qgs file in one user’s C:\Users
>> directory that isn’t there for the user who still has the toolbar. Â
>> I’ve
>> emptied the .qgis directory for the problem user, but that hasn’t
>> changed
>> anything.
>> Any suggestion on how to restore the default settings when they are
>> inadvertently changed?
> Look for qgis related keys in the windows registry.
> Goyo
