[Qgis-user] Re: Sextante plugin works except with GRASS
Pietro Rossin
pierigis at gmail.com
Fri May 11 02:19:30 PDT 2012
Well
Is this the right place to discuss about a description-file
modification/creation or is there a better place to post in?
Just to not overload the mailing list
p
2012/5/11 Paolo Cavallini [via OSGeo.org] <
ml-node+s1560n4967899h14 at n6.nabble.com>
> Il 11/05/2012 10:17, Pietro Rossin ha scritto:
> > Controlling and editing description files, as described in grass.txt
> file, doesn't
> > seem to be a difficult task for a rookie like me..
> > So I can modify them in case they don't work as expected, test them and
> ask you if
> > it's the case to upload via svn. Is that ok for you?
> Yes, that's the idea. As usual, "patches welcome".
> Thanks Pietro.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Qgis-user mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4967899&i=0>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4967899.html
> To unsubscribe from Sextante plugin works except with GRASS, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4958903&code=cGllcmlnaXNAZ21haWwuY29tfDQ5NTg5MDN8MjMwODY1MTQ5>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/Sextante-plugin-works-except-with-GRASS-tp4958903p4967993.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120511/7bcec495/attachment.html>
