[Qgis-user] QGIS Server on Mac
Thomas Dalbert dalbert at onuma.com
Mon May 14 00:41:55 PDT 2012
Hi Julian,
Thank you so much for your help.
Looking in detail over the instructions, I mixed up the two config files that are described to add the instructions: mapserv_fcgi and qgis-mapserver because I had previously also installed MapServer from KyngChaos. This mixup must have caused the issues.
It all works now fine although I didn't realize that QGIS Server can't be used as a WFS Server and I need to serve vector data. So I ended up going back to MapServer again for this. But I'm still quite glad your information got me on the right track to get QGIS Server running.
Thank you again,
Thomas
Thomas Dalbert
Onuma, Inc.
http://onuma.com
On May 10, 2012, at 8:57 PM, Julian Bogdani wrote:
> Hi Thomas,
> I can confirm you that the 1.7.4-4 build from KyngChaos is built with a working qgis-server.
> Did you create the apache config file as in http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial?
> Did you restart Apache and make sure apache is loading the config file (alias qgis-mapserv/ is correctly redirecting)?
> I remember I had some issues setting up the first time qgis-server. Try to change the "Options" statement in the apache config file to match the below example (my current - working- configuration), restart apache and test.
> <IfModule mod_fastcgi.c>
>   FastCgiConfig -appConnTimeout 60 -idle-timeout 60 -init-start-delay 1 -minProcesses 2 -maxClassProcesses 20 -startDelay 5
>   AddHandler fastcgi-script .fcgi
>   Alias /qgis-mapserv/ /Applications/QGIS.app/Contents/MacOS/fcgi-bin/
>   <Directory /Applications/QGIS.app/Contents/MacOS/fcgi-bin/>
>     AllowOverride None
>     Options +ExecCGI -MultiViews +FollowSymLinks
>     Order allow,deny
>     Allow from all
>   </Directory>
> </IfModule>
> The server directory is the fcgi-bin folder. You can keep unchanged the project file path, but you should provide in this case the full path to the qgis project using the "map" URI parameter
> (http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial > Extensions to WMS > Map parameter).
> If no map parameter is given qgis-server will look for a *.qgs file in the "server directory"
> Hope this helps
> Julian Bogdani
> jbogdani at gmail.com
> http://bradypus.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120513/0208f004/attachment.html>
