[Qgis-user] QGis 1.7.4 possible bug with PostgreSQL/Postgis manual integer primary key?
F T
oukile at gmail.com
Tue May 15 05:16:15 PDT 2012
I think the QGis code should not have this specific behaviour and should
follow the standards.
If the key doesn't contain any informations and is just a number, then OK
we can explicitly tell QGis to use a PostgreSQL sequence to create this
arbitrary number.
In my case, the values of the key come from an other application and I have
to type these values to link the geometrical objects to the database
informations.
I found a workaround : if I change the field type of the key from integer
to bigint then everything works as attended...
QGis doesnt tries anymore to give a value when we don't need it.
But this is not very logical isn't it?
Fabrice
2012/5/15 Bernhard Ströbl <bernhard.stroebl at jena.de>
> Hi Fabrice,
> I think this is the intended behaviour. If you leave it to the user to
> enter the primary key then the db might complain about non-unique keys. On
> the other hand why would you _want_ to assign a certain key? A key is just
> a technical field used to identify a dataset. It should not contain any
> information.
> On my db I have three tables (point, line, polygon) that insert into the
> same table representing a n:m relation. I use a sequence on the db and a
> trigger to assign the next sequence value on INSERT. Apart from that I have
> no need to interfere with my pk values and I am glad, that QGIS takes care
> of that.
> Bernhard
> Am 15.05.2012 13:07, schrieb F T:
>> Hi all,
>> We are not able to set explicitly the value of an integer primary key
>> field.
>> It is possible to set this value with pgAdmin.
>> But when the feature is created with QGis, it takes the next max value
>> of the field and not the spécified value...
>> To reproduce this strange behaviour :
>> -- create a table in the schema public with an integer primary key
>> CREATE TABLE the_table
>> the_key integer NOT NULL,
>> the_obs character varying(150),
>> geom geometry,
>> CONSTRAINT the_table_pkey PRIMARY KEY (the_key),
>> CONSTRAINT enforce_dims_geom CHECK (st_ndims(geom) = 2),
>> CONSTRAINT enforce_geotype_geom CHECK (geometrytype(geom) =
>> 'MULTILINESTRING'::text OR geom IS NULL),
>> CONSTRAINT enforce_srid_geom CHECK (st_srid(geom) = 2154)
>> WITH (
>> OIDS=TRUE
>> -- spatialize the table
>> INSERT INTO geometry_columns(f_table_**catalog, f_table_schema,
>> f_table_name, f_geometry_column, coord_dimension, srid, "type")
>> VALUES('', 'public', 'the_table', 'geom', 2, 2154, 'MULTILINESTRING');
>> Then in QGIS :
>> - add this table to a project
>> - create 1 line with the_key=100 and save the edition -> open the
>> attribute table and you see the_key=0
>> - create 1 line with the_key=102 and save the edition -> open the
>> attribute table and you see the_key=1
>> If I modify the value of the_key in pgAdmin, by example put the value
>> 1000 instead of 1, then the next line created with QGis will have the
>> value 1001.
>> Any help is welcome !
>> Thanks
>> Fabrice
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120515/2266fc6f/attachment.html>
