[Qgis-user] QGIS and Oracle spatial
G. Allegri giohappy at gmail.com
Wed May 16 06:11:03 PDT 2012
Hi Donner,
it's possible through the OGR driver, but it depends on GDAL if they've
been created with Oracle support (which is not the default case).
If you're on Windows, Osgeo4W provides GDAL/OGR and the Oracle driver, so
you can connect to Oracle spatial in two ways:
1 - Layer -> Add Vector Layer -> Database. If Oracle is supported by
GDAL/OGR it should be listed inside the Database options
2 - create a VRT file, with the right connection parameters, and load the
file from QGis (Layer -> Add Vector Layer -> File)
Consider that the OGR-Oracle bridge is not very mich efficient with high
volumes of features...
giovanni
2012/5/16 Donner Jan <Jan.Donner at fonecta.com>
> Hi!
> Can someone tell what the support for Oracle Spatial is like in Qgis?
> Is it posiible to view and edit data directly in the database Thanks, Jan
> Donner
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120516/dca47258/attachment.html>
