[Qgis-user] Need help.
    Water Loo
    waterloo4134 at hotmail.com
    Wed May 16 23:09:49 PDT 2012
Hi, I use google map as my base map. Today a small window pop up and I cann't close the small window as attached.
 Please help. Thank You Water.> From: qgis-user-request at lists.osgeo.org
> Subject: Qgis-user Digest, Vol 75, Issue 54
> To: qgis-user at lists.osgeo.org
> Date: Wed, 16 May 2012 11:59:32 -0400
> Send Qgis-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. qgis_mapserv.fcgi for a wms for maemo-mapper (Enrico Gabrielli)
>    2. qgis_mapserv.fcgi for a wms for maemo-mapper (Enrico Gabrielli)
>    3. Re: qgis_mapserv.fcgi for a wms for maemo-mapper
>       (Marco Hugentobler)
>    4. How does the postgis connection work? (fork)
>    5. Re: Openlayer plugin performance ideas? (mayeul.kauffmann at free.fr)
>    6. Re: Openlayer plugin performance ideas? (fork)
> Message: 1
> Date: Wed, 16 May 2012 16:50:00 +0200
> From: Enrico Gabrielli <bonushenricus at linux.it>
> Subject: [Qgis-user] qgis_mapserv.fcgi for a wms for maemo-mapper
> Message-ID: <1337179800.10148.9.camel at debian.sanrocco.local>
> Content-Type: text/plain; charset="UTF-8"
> Hi
> I'm trying to trasform my qgis project in a wms service
> because I would to download the map into maemo-mapper before I will go
> to farmers.
> I try with this
> http://localhost/cgi-bin/qgis_mapserv.fcgi?map=/usr/lib/cgi.bin/project/2012_ASSICURAZIONE_WMS.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=10.9154999999999998,44.6850000000000023,11.3047000000000004,44.9189999999999969&CRS=EPSG:4326&WIDTH=722&HEIGHT=352&LAYERS=partita_assicurativa_riepilogo_2012_geom&FORMAT=image/png
> and it doesn't work: it say me there isn't a style sheet!
> After understand the correct url I believe will be sufficient change
> localhost with the ip adress and connect the nokia n800 in the local
> net.
> Is it possible?
> Thank you
> Message: 2
> Hi
> to farmers.
> I try with this
> net.
> Is it possible?
> Thank you
> Message: 3
> Date: Wed, 16 May 2012 17:12:08 +0200
> From: Marco Hugentobler <marco.hugentobler at sourcepole.ch>
> Subject: Re: [Qgis-user] qgis_mapserv.fcgi for a wms for maemo-mapper
> Message-ID: <4FB3C3C8.5010403 at sourcepole.ch>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> Hi Enrico
> Should it be
> ...map=/usr/lib/cgi-bin/project/2012_ASSICURAZIONE_WMS.qgs...
> in the URL?
> Regards,
> Marco
> Am 16.05.2012 16:50, schrieb Enrico Gabrielli:
> > Hi
> > to farmers.
> > I try with this
> > net.
> > Is it possible?
> > Thank you
> > Qgis-user at lists.osgeo.org
> Dr. Marco Hugentobler
> Sourcepole -  Linux&  Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Message: 4
> Date: Wed, 16 May 2012 15:25:26 +0000 (UTC)
> From: fork <forkandwait at gmail.com>
> Subject: [Qgis-user] How does the postgis connection work?
> Message-ID: <loom.20120516T172352-5 at post.gmane.org>
> Content-Type: text/plain; charset=us-ascii
> ... besides "very well" is what I mean:
> When I insert into a table at the psql prompt, it gets propagated to the map
> quickly -- is that through a hook on the commit statement, a notice, or what?
> In any case, it is seamless so far and really great to work with
> Message: 5
> Date: Wed, 16 May 2012 17:41:25 +0200 (CEST)
> From: mayeul.kauffmann at free.fr
> Subject: Re: [Qgis-user] Openlayer plugin performance ideas?
> To: fork <forkandwait at gmail.com>
> Cc: qgis-user at lists.osgeo.org
> Message-ID:
> 	<467027381.206550674.1337182885848.JavaMail.root at zimbra73-e12.priv.proxad.net>
> Content-Type: text/plain; charset=utf-8
> >  I don't want to download a bazillion image files
> Anyway Google maps terms of use probably forbid this. (Same for Bing?).
> You may try with Bing tiles, they have static tiles that are easier to get and their banning policy is, I believe, not as strict, which may be easier to work with.
> And / or  you may try to see if you can cache the tiles using a local proxy server. The code given in the following page works very well for caching OSM tiles with the OpenLayers plugin in QGIS:
> http://wiki.openstreetmap.org/wiki/ProxySimplePHP
> Finally, all would be faster if the plugin could display the image even when there are a few tiles missing. I filed a ticket for this some times ago. If you have developing skills you may try to help here.
> Mayeul
> ----- Mail original -----
> De: "fork" <forkandwait at gmail.com>
> À: qgis-user at lists.osgeo.org
> Envoyé: Mardi 15 Mai 2012 17:59:42
> Objet: [Qgis-user] Openlayer plugin performance ideas?
> Hi all,
> I have a project in which I basically have two large base maps -- an openlayers
> plugin map from google (hybrid), and a postgis vector layer with all the census
> blocks for the entire state of Oregon.  I zoom in and out of the map looking at
> various attributes in the block to see if they match buildings shown in the
> areal image (specifically, whether large group quarters numbers in the block
> correspond to large buildings in the block as well).
> Often I will query the block layer to constrain it to a given city and with
> blocks that have a certain attribute ("cityname10='Newport' and gq10>=10"), and
> zoom to those blocks using the attribute table.  Sometimes I just do a
> constraint like gq>=100 and look at the whole state.
> The block layer only renders when the scale is 25000:1 or less.
> This works fine as it is, but it can be a little bit pokey when the openlayers
> image is open. If I turn off the image, it is darn fast.  I would like to try
> scale dependent rendering, but I can't get a properties dialogue.
> Does anybody have any ideas on how to speed this up, and still do it on a
> statewide scale (ie, if I can
> avoid it)?
> It works pretty well as it is, I just want it faster. ;)
> Message: 6
> Date: Wed, 16 May 2012 15:50:22 +0000 (UTC)
> Subject: [Qgis-user] Re: Openlayer plugin performance ideas?
> Message-ID: <loom.20120516T174710-359 at post.gmane.org>
> fork <forkandwait at ...> writes:
> > statewide scale (ie I don't want to download a bazillion image files, if I can
> > avoid it)?
> For great speed, I am now using the OSM layers for streets and landscape.  It
> doesn't give you that satellite detail, but if I turn on the satellite only when
> I need to look at buildings (as opposed to orient myself), it speeds up the
> process.
> Mayeul -- I wish I had the dev skills to help with the plugin -- I am
> overcommitted these days, and can only offer moral support and kudos to the
> excellent plugin
> End of Qgis-user Digest, Vol 75, Issue 54
https://skydrive.live.com/redir.aspx?cid=e037a4004123c617&page=browse&resid=E037A4004123C617!111&sc=Documents&authkey=!ANCgzykIx73PJbU&Bpub=SDX.SkyDrive&Bsrc=SkyMail
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120517/63dc0b61/attachment.html>
