[Qgis-user] Hyperlink to EXCEL und Word
Rudi Thiede
rudi at linfiniti.com
Thu May 17 00:10:28 PDT 2012
Hi Daniela,
Do this the same way you open an image etc., but set the "Type" to "Open".
As the "Action," specify only the field name, z.B. '[% "fieldname" %]'.
This should work for any file type actually, it will open the file with the
default program on any user's computer. On mine it's OpenOffice, on someone
else's computer it could be MS Office, for example. So it's not necessary
to find out the path to the program .exe itself, which also is not the same
for everyone...
Regards
R Thiede
On 16 May 2012 18:48, Micha Silver <micha at arava.co.il> wrote:
> On 16/05/2012 17:19, Wörz Daniela wrote:
> Hy there,
> is there allready a way to hyperlink to EXCEL and WORD Documents?
> Have not found a not yet about it, only for Pictures/Pdf and to Websites -
> those do
> not work to EXCEL and WORD Documents.
> You just need to put the path to winword.exe (or excel.exe) in to action
> definition, and add a column with the full path to the WORD or EXCEL doc
> for each row/feature.
> Thanks for any tip
> Daniela Wörz
> This mail was received via Mail-SeCure System.
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120517/6cc0ba00/attachment.html>
