[Qgis-user] Re: QGIS cannot read .nc files on my Windows7 64 Bits
MattJack
mathieu at yadusurf.com
Thu May 17 08:58:32 PDT 2012
Thank you for your answer Etienne,
> which version of gdal did you install in osgeo4w?
I used the installer linked in http://trac.osgeo.org/osgeo4w/ this OSGEO4W
page , and just run a "standard" installation.
I did not know it was possible to choose a version of GDAL.
gdalinfo --version says :
GDAL 1.7.3, released 2010/11/10
>try this and see if NetCDF shows up, if not then the build does NOT have
netcdf support (haven't >checked)
>gdalinfo --formats
Yes you are right, NetCDF is not listed (and neither HDF4 and HDF4Image)
> If it does show up, can you try the following and post here:
> gdalinfo --debug on loire.nc
Here is the output:
ERROR 4: `loire.nc' not recognised as a supported file format.
gdalinfo failed - unable to open 'loire.nc'.
GDAL: GDALDeregister_GTiff() called.
> ncdump -h loire.nc
ncdump looks to be pre-installed in OSGeo4W.
ncdump could open loire.nc, and outputted lots of metadata. Here are the
first lines (to show the format)
netcdf loire { // format variant: 64bit
dimensions:
time = UNLIMITED ; // (1 currently)
longitude = 301 ;
latitude = 331 ;
So it looks like, as it is, GDAL does not include netcdf??
Mathieu
View this message in context: http://osgeo-org.1560.n6.nabble.com/QGIS-cannot-read-nc-files-on-my-Windows7-64-Bits-tp4975239p4975411.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
