[Qgis-user] QGis 1.7.4 possible bug with PostgreSQL/Postgis	manual integer primary key?
    Lee Hachadoorian
    Lee.Hachadoorian+L at gmail.com
    Thu May 17 09:23:12 PDT 2012
Fabrice,
I filed a bug report, and it turns out this has already been fixed in
the development version.
http://hub.qgis.org/issues/5608
--Lee
On Wed, May 16, 2012 at 1:39 PM, Lee Hachadoorian
<Lee.Hachadoorian+L at gmail.com> wrote:
> On 05/16/2012 02:41 AM, Bernhard Ströbl wrote:
>> I agree, so if the user enters a value it should be passed to the database
>> and not discarded. If it violates any database rules postgresql complains
>> anyways. So this could be a bug then.
>>> BTW, I found I could *edit* the primary key field of a table with a
>>> key field typed as serial, but when I tried to add a new feature, any
>>> value entered manually generated a primary key violation. The column
>>> value in QGIS defaulted to nextval('sequence_name'::regclass),
>>> matching the column default in the table definition, but also
>>> generated a primary key violation. When I cleared the field
>>> completely, the row was added with the next available value from the
>>> sequence.
>> not confirmed here (PostgreSQL 8.4, QGIS 1.7.4)
>> primary key is integer with a nextval('sequence') default
>> adding features the key field defaults to nextval('sequence')
>> case 1) no change => nextval applied
>> case 2) change value => nextval applied (no error, though)
>> expected behaviour for case 2) would be to not apply the default
>> shall we file a ticket for this?
>> Bernhard
> OK, I have added a ticket for this behavior. Note that my previous
> complaint--any supplied value generates a primary key violation--was tested
> on Windows. Testing just now on Ubuntu, I observe same behavior as you and
> OP. I have filed the ticket accordingly. I want to retest on Windows, and
> then will amend ticket or file new bug report.
>>>>> I found a workaround : if I change the field type of the key from
>>>>> integer to bigint then everything works as attended...
>>>>> QGis doesnt tries anymore to give a value when we don't need it.
>>>>> But this is not very logical isn't it?
>>>>> Fabrice
> Fabrice, it seems that QGIS does allow you to edit an existing feature, so
> another workaround would be to add feature, save changes allowing Postgres
> to assign default value from sequence, then edit to change to the desired
> value.
> --Lee
> Lee Hachadoorian
> PhD, Earth&  Environmental Sciences (Geography)
> Research Associate, CUNY Center for Urban Research
> http://freecity.commons.gc.cuny.edu
Lee Hachadoorian
PhD, Earth & Environmental Sciences (Geography)
http://freecity.commons.gc.cuny.edu/
