[Qgis-user] Live GPS Tracking not working
Steve Jones
sjones16 at ymail.com
Mon May 21 17:07:07 PDT 2012
Hello, I have a Garmin 62s. I have not been able to get Live GPS Tracking to work.
I tested my unit, gpsmon indicates that gpsd is functioning properly (see GPSMON OUTPUT below for screen output).
If I run qgis as root, I get a series of messages in my xterm window (see QGIS XTERM OUTPUT).
However, when I attempt to create a live tracking connection in qgis via gpsd (host: localhost, port: 2947, device /dev/ttyUSB0) no gps information is displayed.
I have also tried to
GPSMON OUTPUT
localhost:2947: Garmin Serial binary>
Time: 2012-05-21T23:47:00.000Z ":6,
┌─── Position ───┐┌──── Satellite
──────┐ tivated"
│ Fix: no fix ││Ch PRN Az El SNR ST│ "1113: 3
│ Lat: 43.67969°││ 0 7 175 62 16.7 15│
│ Lon: -79.35159││ 1 19 52 49 17.5 15│ alse,"ti
Alt: 131.09m││ 2 8 297 66 21.8 15│
│ Speed: 0.0m/s││ 3 11 128 55 21.1 15│
│ Climb: 0.0m/s││ 4 1 146 38 -1.0 14│
│ Leap: 15sec ││ 5 3 58 14 -1.0 14│
│ epe: nanm ││ 6 6 55 3 -1.0 14│
│ eph: nanm ││ 7 13 199 4 -1.0 14│
│ epv: nanm ││ 8 17 232 14 -1.0 14│
└── ID 51 (0x33) ┘│ 9 26 309 19 -1.0 14│
│10 28 292 34 -1.0 14│
│11 255 0 0 0.0
0│
└─── ID 114 (0x72) ───┘
edcaa3abbd28f6bf0000000000000000000000009f4211420f00f01f0000321003
SAT 0x72=(90) 1072540788063eaf001513d40631340015088508422901150b3e0837800015019cff269200
14039cff0e3a0014069cff033700140d9cff04c70014119cff0ee800141a9cff133501141c9cff22240114ff
000000000000581003
PVT 0x33=(70) 103340668abd4212613542d48c5e422a3c0f420100000000005803054186e016033565e83f
edcaa3abbd28f6bf0000000000000000000000009f4211420f00f01f00002a1003
QGIS XTERM OUTPUT
(process:6364): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Did not
receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Warning: QGtkStyle was unable to detect the current GTK+ theme.
Warning: Qt: Session management error: None of the authentication protocols specified are
supported
Warning: loading of qgis translation failed [/usr/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed [/usr/share/qt4/translations/qt_en_US]
Python support ENABLED :-)
Loaded : fTools (package: fTools)
Loaded : Plugin Installer (package: plugin_installer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120521/4e5c1a66/attachment.html>
