[Qgis-user] User error or bug? (Vector Symetric Difference)
Adam Hirsch
adam.e.hirsch at gmail.com
Wed May 23 10:40:14 PDT 2012
Hey, folks -- I'm a fairly new QGIS user trying to run the amusingly misspelled "Symetric Difference" vector tool against two vector layers. Unfortunately, whenever I do, the CPU spikes to 100% and QGIS seizes up, producing no output. Same problem with "Union," though other Vector tools seem to work okay.
I'm new to QGIS, so I wanted to check and see whether I was missing something obvious before filing a bug on it. http://hub.qgis.org/issues/5626 sounds somewhat similar, but I'm running on local files without a PostGIS back, so it might not be the same.
Thanks!
Adam
Faced with the choice between changing one's mind and proving that there is
no need to do so, almost everybody gets busy on the proof. -J.K. Galbraith
<adam.e.hirsch at gmail.com> Adam Hirsch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120523/ff79fde7/attachment.html>
