[Qgis-user] Re: QGis on Ubuntu 12.04
    Luís de Sousa
    luis.a.de.sousa at gmail.com
    Thu May 24 01:57:56 PDT 2012
Hi Giovanni,
Thank you for the link. Unfortunately, installing qgis from that ppa is
resulting in the error that goes below. This is shown by a popup menu from
the software centre, not at the command line. As I understand it, the
package grass642 is failing to install; is there any work around?
Thank you.
Unpacking grass-core (from .../grass-core_6.4.2-2~precise2_amd64.deb) ...
dpkg: error processing
/var/cache/apt/archives/grass-core_6.4.2-2~precise2_amd64.deb (--unpack):
 trying to overwrite '/usr/bin/x-grass', which is also in package grass
6.4.1-2~oneiric1
No apport report written because MaxReports is reached already
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Errors were encountered while processing:
Error in function:
dpkg: dependency problems prevent configuration of libgdal1-1.9.0-grass:
 libgdal1-1.9.0-grass depends on grass642; however:
  Package grass642 is not installed.
dpkg: error processing libgdal1-1.9.0-grass (--configure):
 dependency problems - leaving unconfigured
View this message in context: http://osgeo-org.1560.n6.nabble.com/QGis-on-Ubuntu-12-04-tp4967969p4976557.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
