[Qgis-user] Georeferencing
William Kyngesburye
woklist at kyngchaos.com
Thu May 24 15:25:05 PDT 2012
Known issue:
http://hub.qgis.org/issues/3743
If you have the screen space, try resizing windows so the coordinate dialog is always visible, even if it's just a part of the window. There's a better explanation in the bug report.
On May 24, 2012, at 11:38 AM, Diana Jones wrote:
> Just wanted to make the developers aware that when I use the Plug-In georeferencer in 1.7.4 for Mac OSX, the 'Enter Coordinates' box is always found hiding behind the main panel and the georeferencing panel on the screen, so that in order to access the box, both panels need to be minimised first. This becomes tedious when there are many points to geoference.
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
