[Qgis-user] shapefile/dbf number limitation?
Giovanni Manghi giovanni.manghi at faunalia.pt
Sun May 27 16:30:31 PDT 2012
> The field contained an object_id. An attempt to save/export selected
> features of the shapefile let all the object_id fields be filled with
> -2147483648 values.
> Did some testing with that field definition (Real, length 19, precision 0)
> and only the range of values between 2147483647 and -2147483648 seems to be
> insertable. Beyond that, -2147483648 appears in the fields after saving the
> table. The object_id in the original shapefile exceeded the mentioned value
> range.
that range is the one for int4 column types, see for example
http://www.postgresql.org/docs/9.1/static/datatype-numeric.html
can the dbf format store numbers outside this range?
Please see also
http://hub.qgis.org/issues/5546
add your notes and eventually suggest a new title/description.
Cheers
-- Giovanni --
