[Qgis-user] How to open ESRI geodatabase in QGIS 1.8 and Gdal 1.9 on Ubuntu?
Johan Nilsson joni8135 at gmail.com
Wed Nov 7 09:47:10 PST 2012
Peter. I think Add-vector-->Database-->ESRI personal geodatabase, are just
Personal Geodatabase, aka a JET-db or MS-access-database? ESRIs File
database are what ESRI recommend to use, not the MS-Access typ of db
because of bad preformance add a size limit of 1GB.
I stilll try to understand what I need to do with GDAL and the
ESRI-FileGDB... I need to uninstall the old GDAL things and stuff? Don't
what to break the system...
Cheers
2012/11/7 Peter Schürch <p.schuerch at meierpartner.ch>
> I think I managed to open ESRI Geodatabase as a Database source without
> any tweaking opening them as a Vectorfile and then choosing Database
> (instead of File).****
> Peter ****
> QGis 1.8, Windows 7****
> Meier und Partner AG, Switzerland, www.meierpartner.ch****
> *Von:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *Im Auftrag von *Johan Nilsson
> *Gesendet:* Mittwoch, 7. November 2012 13:07
> *An:* qgis-user
> *Betreff:* Re: [Qgis-user] How to open ESRI geodatabase in QGIS 1.8 and
> Gdal 1.9 on Ubuntu?****
> Thanx. Downloadig the FileGDB_API_1_2-32.tar.gz and also the 64-bit
> version.
> I have only compiled one thing in Ubuntu and that was a component in Unity
> (to get navigation buttom, to the left in stead of right, and during that I
> have a row, to row tutorial.
> Can this help me?
> https://github.com/usgin/ncgmp/wiki/Installation-Example
> Thanx for al tips and helps /Cheers****
> 2012/11/7 Alex Mandel <tech_dev at wildintellect.com>****
> On 11/06/2012 10:43 PM, Johan Nilsson wrote:
> > How do I open ESRIs geodatabase .gdb-files in QGIS 1.8 and Gdal 1.9? I
> have
> > found on internet that the package OSGeo4W are needed, but this is only
> för
> > ms-windows, i suppose, but I run Ubuntu 12.04LTS. As I understand it, is
> > should also only bee possible for ArcGIS 10, not older versions of
> ArcGIS.
> > By the way, .gdb appears in Ubuntu as a folder with lot of files inside.
> > /Cheers Jjohan N
> They can be opened on either Windows or Linux, what you need is the
> gdal/ogr file geodatabase driver. This requires getting some files from
> ESRI (free) and doing a little bit of compiling.
> I found this which should help. But I though there was a way that didn't
> require a complete gdal compile.
> http://www.paolocorti.net/2012/01/10/gdal_19_released/
> As for ArcGIS, there are several versions of Geodatabases, newer Arcs
> can read older databases but not vice versa.
> Thanks,
> Alex
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-user****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121107/a450d6cf/attachment.html>
