[Qgis-user] QGIS Workspace Packager Tool?
Andreas Neumann
a.neumann at carto.net
Thu Nov 8 03:10:15 PST 2012
I don't understand the need for a packaging tool.
If you organize everything with relative paths and everything
well-organized in a project directory you can just zip this directory,
move it to a different machine and everything should work fine.
Where exactly is there a problem with packaging the project?
Andreas
On Thu, 08 Nov 2012 11:30:08 +0100, Bernd Vogelgesang wrote:
> as i experienced some time ago, QConsolidate only handles shape files
> or attached dbf tables, but didn't work(or even hung) on spatialite
> layers.
> And i think it didn't take rasters as well.
> So using QConsolidates "works" on certain projects very well, but is
> definately not a complete solution for cases with raster data and
> other data providers.
> Am 08.11.2012, 08:02 Uhr, schrieb Nathan Woodrow
> <madmanwoo at gmail.com>:
>> Hey ben,
>> Checkout the QConsolidate plugin. It will create shape files over
>> all the
>> layers and change the project to point to those new layers.
>> - Nathan
>> From: Ben Jones
>> Sent: 8/11/2012 4:48 PM
>> To: qgis-user at lists.osgeo.org
>> Subject: [Qgis-user] QGIS Workspace Packager Tool?
>> Dear All,
>> Is it possible to save a copy of a QGIS workspace and all the linked
>> data
>> files used by the workspace to a new folder so that the new
>> workspace can
>> be opened no matter where the folder is moved or copied, even if the
>> folder
>> is moved or copied to a different computer (ie something like the
>> MapInfo
>> "Workspace Packager" tool). Thanks,
>> Ben
>> Ben Jones
>> bmjones at iprimus.com.au
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
