[Qgis-user] SVG export New Symbology [was Text symbols]
Peter Schürch
p.schuerch at meierpartner.ch
Tue Oct 2 01:58:34 PDT 2012
I can report back:
Newstyle labels are not exported as text to SVG. This is indeed a problem.
Problem with Oldstyle labels is that buffers don't work, which is quite essential too if you annotate your data.
I'm running:
QGIS version
1.8.0-Lisboa
QGIS code revision
6416f38
Peter
-----Ursprüngliche Nachricht-----
Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Alex Mandel
Gesendet: Freitag, 28. September 2012 20:21
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] SVG export New Symbology [was Text symbols]
On 09/28/2012 12:57 AM, Peter Schürch wrote:
> Hi Stephen
> You can place a buffer around the text, that enhances readability a lot. If you want to export your map to pdf or svg you should use new-style labelling (the Icon with the letters "ABC" on the toolbar), otherwise export fails. New-style labelling allows you to place labels parallel to lines, could be quite useful too.
Last time I checked the results with old Labeling and old Symbology were more compatible with SVG export. Specifically the New stuff didn't keep text as text which is a problem for SVG cleanup.
Did this change in 1.8?
Thanks,
Alex
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
