[Qgis-user] Problems compiling QGIS under OS X 10.8.2
Etienne Tourigny
etourigny.dev at gmail.com
Sat Oct 13 12:38:50 PDT 2012
try adding
-DPYTHON_LIBRARY=<path_to_python_libdir>/libpython2.7.so
I use that option in linux, not sure if it works on mac osx
also, have you followed KyngChaos' instructions for building?
Etienne
On Sat, Oct 13, 2012 at 3:12 PM, Sasha Cuerda <sasha.cuerda at gmail.com> wrote:
> Hello,
> I am having some difficulties compiling QGIS and I'm hoping someone here can
> help…I have a hunch that the source of this problem is with Python but I'm
> not very sophisticated when it comes to application development.
> I have installed all required dependencies using a combination of Homebrew
> and manual installation (adding symbolic links when necessary).
> I followed the recommendations of homebrew in regards to SIP and issued the
> following command prior to initiating the build:
> export PYTHONPATH=/usr/local/lib/python2.7/site-packages:$PYTHONPATH
> I am trying to use the following command to initiate the build:
> cmake -D CMAKE_INSTALL_PREFIX=/volumes/Main/Applications \
> -D CMAKE_BUILD_TYPE=MinSizeRel \
> -D ENABLE_TESTS=FALSE \
> -D WITH_INTERNAL_SPATIALITE=FALSE \
> -D WITH_PYSPATIALITE=FALSE \
> -D WITH_GRASS=TRUE \
> -D GRASS_PREFIX=/usr/local/bin/ \
> -D QWT_LIBRARY=/usr/local/Cellar/qwt/6.0.1/lib/qwt.framework \
> -D QWT_INCLUDE_DIR=/usr/local/Cellar/qwt/6.0.1/lib/qwt.framework/Headers \
> -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
> -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
> -D BISON_EXECUTABLE=/usr/local/bin/bison \
> -D EXPAT_LIBRARY=/usr/local/lib/libexpat.dylib \
> -D EXPAT_INCLUDE_DIR=/usr/local/include \
> -D GEOS_INCLUDE_DIR=/usr/local/include \
> -D GEOS_LIBRARY=/usr/local/lib/libgeos_c.dylib \
> -D GDAL_INCLUDE_DIR=/usr/local/include \
> -D GDAL_LIBRARY=/usr/local/lib/libgdal.dylib \
> -D GSL_INCLUDE_DIR=/usr/local/include \
> -D GSL_LIBRARIES=/usr/local/lib/libgsl.dylib \
> -D POSTGRES_INCLUDE_DIR=/usr/local/include \
> -D POSTGRES_LIBRARY=/usr/local/lib/libpq.dylib \
> I get the following output:
> -- Quantum GIS version: 1.9.0 Master (10900)
> -- Could not find GRASS
> -- Found Proj: /Library/Frameworks/PROJ.framework
> -- Found GEOS: /usr/local/lib/libgeos_c.dylib
> -- Found GDAL: /usr/local/lib/libgdal.dylib (1.9.2)
> -- Found Expat: /usr/local/lib/libexpat.dylib
> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
> -- Found Qwt: /usr/local/Cellar/qwt/6.0.1/lib/qwt.framework (6.0.1)
> -- Found Sqlite3: /Library/Frameworks/sqlite3.framework
> -- Found PostgreSQL: /usr/local/lib/libpq.dylib
> -- Touch support disabled
> -- Pedantic compiler settings enabled
> /usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python:
> can't open file '_find_lib_python_py-NOTFOUND': [Errno 2] No such file or
> directory
> -- Found Python executable: /usr/local/bin/python2.7
> -- Found Python version:
> -- Found Python library: /usr/local/lib/python2.7/
> can't open file '_find_sip_py-NOTFOUND': [Errno 2] No such file or directory
> CMake Error at cmake/FindSIP.cmake:54 (MESSAGE):
> Could not find SIP
> Call Stack (most recent call first):
> CMakeLists.txt:494 (FIND_PACKAGE)
> If I run python FindSIP.py from the CMAKE folder, I get this:
> sip_version:040e00
> sip_version_num:265728
> sip_version_str:4.14
> sip_bin:/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/bin/sip
> default_sip_dir:/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/share/sip
> sip_inc_dir:/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/include/python2.7
> sip_mod_dir:/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
> Which is what I would expect.
> Any idea what is going on here and how to fix it?
> Thanks in advance for any help you can provide.
> -Sasha
> Qgis-user mailing list
