[Qgis-user] QGIS customization
Radim Blazek
radim.blazek at gmail.com
Mon Oct 15 01:24:24 PDT 2012
On Sat, Oct 13, 2012 at 10:13 PM, Stephan Breisig
<post at stephanbreisig.de> wrote:
> Hi Radim,
> by chance I have read in Nathan Woodrow's blog that you and Martin Dobias
> developed a customization tool for QGIS which is now included in the master.
> Since I'm interested in this tool, I looked for further information about it
> but didn't find much except for one of your posts on OSGeo
> (http://osgeo-org.1560.n6.nabble.com/QBrowser-amp-Customization-td4103113.html
> - unfortunatelly the link to Picasa therein is dead). Can you give me some
> instructions how to use/access this tool? I work with the current nightly
> build of QGIS.
Settings > Customization
It should be obvious, you can hide various parts of GUI. The only
tricky thing is use of the interactive select tool - once you switch
into select mode, you can only set on/off various parts of a
customized dialog, but cannot anymore change tabs etc., you need to
switch back to normal mode (and you cannot even switch the tool off by
click on toolbutton), you have to use CTRL-M to switch between select
and normal mode.
CC to mailing list for others.
Radim
> Greetings,
> Stephan
> Stephan Breisig
> Dipl.-Geol., M.Eng.
> Oderstrasse 8 Tel.: +49-2602-997787
> D-56410 Montabaur Email: post at stephanbreisig.de
