[Qgis-user] Qgis Styles
Johan Nilsson
joni8135 at gmail.com
Wed Oct 17 14:41:24 PDT 2012
I have not used it yet so I'm not sure, but I think the only way is to use
the open standard formate SLD
http://underdark.wordpress.com/2012/06/03/sld-support-and-other-qgis1-8-style-features/
There are also possible to make this in ArcGIS
http://gis.stackexchange.com/questions/3755/how-to-edit-or-convert-ar
And also MapInfo can read and create SDL-files.
How does it work to exange style defined layer files between MapInfo and
ArcGIS? Even there may the use of SLD as layer style make it easier? If i'm
not correct, pleas correct me.
Cheers
/Johan
2012/10/17 Ben Jones <bmjones at iprimus.com.au>
> I am a new user to Qgis and this list. I have colleagues that work with
> MapInfo and ArcGIS and am using .tab and .shp files in Qgis. Two questions:
> 1) Is possible to import styles that were assigned to shape files and tab
> files in MapInfo and ArcGIS (respectively) into Qgis (ie styles saved in an
> ArcGIS layer .lyr file)?
> 2) Alternatively is there a repository of additional polygon fill styles
> that can be loaded in Qgis (the existing fill styles appear to be very
> limited)?
> Help will be very much appreciated.
> Thanks,
> Ben
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121017/4d832dcf/attachment.html>
