[Qgis-user] QGIS-Webclient Layer-visibility
G. Allegri
giohappy at gmail.com
Fri Oct 19 00:18:52 PDT 2012
I have solved this problem (and others) using server code. In my case I'm
working on a Django project which acts as a proxy between qgis-web-client
and qgis-server.
Without something like this the only options would
- (generic) be to implement a method inside qgis-server which could pass
the qgis project to the client, probably in a json-formatted fashion
- (specific) implement methods to retrieve specific informations about the
qgis project, like the layer visibility
giovanni
2012/10/19 Dieter Becker <webmapping.dieter at gmail.com>
> Dear QGIS-users,
> I have got a questions concerning the layer-visibility of the
> QGIS-Webclient:
> In some older mails (11/2011) of this mailinglist I found following
> information:
> There is also a pending feature in QGIS server that should allow to
> retrieve layer visibility from the GetCapabilities XML document, thus
> eliminating the need to manually set layer visibility.
> Andreas
> Does someone of you know if there is found a convienient way in the
> meantime to automatically determine the visible layers of a qgis-project so
> that there is no need to write down everey layer for the rest-adress?
> I know that for example the qgis-cloud-plugin for QGIS produces a
> js-config file that has the information about visible layers and
> start-/maxExtent.
> But is there also way to use something like this if I want to host my own
> webclient?
> best wishes,
> Dieter
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/5ec1e8bf/attachment.html>
