[Qgis-user] QGIS Webclient with two cgi-bin-directorys?
G. Allegri
giohappy at gmail.com
Fri Oct 19 00:24:56 PDT 2012
The simplest maybe would be to symlink the qgis-mapserver.fcgi to another
file and use File level password protection.
http://httpd.apache.org/docs/2.2/mod/core.html#files
I suggest you to consider the Lizmap application, which gives you the
opportunity to set authentications for each qgis project.
(and probably my Django project in a near future :))
giovanni
2012/10/19 Dieter Becker <webmapping.dieter at gmail.com>
> Dear QGIS-users,
> I have got a questions concerning the QGIS-Webclient:
> I try to implement a webmapping-solution with qgis-server and qgis
> webclient.
> At the moment I have got this application running with
> login/password-restriction for the cgi-bin-folder as well as the webclient
> itself so that also the WMS-services are password-protected.
> Now I would also make it possible to produce some none-password-protected
> WMS-services at the same time?
> Is it possible just to use two cgi-bin folders and not to encrypt the
> second one?
> Did someone of you already has such a system up and running with a mixture
> of encrypted and non-encrypted services?
> best wishes,
> Dieter
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/82195b3c/attachment.html>
