[Qgis-user] missing folder path in SEXTANTE for Mac OS X
Victor Olaya volayaf at gmail.com
Fri Oct 19 02:49:07 PDT 2012
No, that is not a problem
If you are running Linux or Mac, GRASS and SAGA should be on your path, so
there is no need to tell SEXTANTE where they are.
I haven't done testing in Mac, so I cannot tell you much more about why it
is not finding GRASS...sorry :-(  If you open a console and you can start
grass, then you should not have problems. If not, make sure that GRASS is
installed and in your path.
Maybe someone with a Mac who has worked with SEXTANTE can help you more
that I can...
Regards
VIctor
2012/10/19 Irene Palumbo <ire.palumbo at gmail.com>
> Hi to everyone!
> Hoping this will help…
> I'm working with platform OS X 10.8.2 (12C60) -Mountain Lion-
> After installing the plugin SEXTANTE v. 1.0.7 ,while using the Sextante
>  Toolbox, I get an error message (see attached) for every command I choose
> in GRASS
> *Error text:*
> *Could not load layer:
> /Users/Ire/sextante/tempdata/grassvbufferdistance7.shp*
> *Check the SEXTANTE log to look for errors in algorithm execution*
> *Algotithm History:*
> *Sextante.runalg("grass:v.buffer.distance","/Users/Ire/Desktop/QGIS
> corso/Dati_corso_QGIS/punti.shp","100","0.01",False,False,None)*
> *Sextante.runalg("grass:v.to.rast.value","/Users/Ire/Desktop/QGIS
> corso/Dati_corso_QGIS/fiumi.shp",0,1,None)*
> I noticed that in the options menu, in Grass configuration (and with SAGA
> is the same) is missing the line to enter the path for the GRASS folder,
> but I don't know if this is the real problem. (I've attached some images,
> because I'm not sure to have explained correctly what I meant….)
> Thanks!
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/7e4d6e0f/attachment.html>
