[Qgis-user] scae on map composer
Matt Boyd
mattslists at gmail.com
Wed Oct 24 16:37:11 PDT 2012
It's all to do with the map units.
If your working in a projected (ie feet, meters etc) then the map
units are very small compared to the scale of the map.
Segment size (map units) : This is how long each segment in the scale
bar will be, a 5km long segment would be 5000 (ie 5000m because your
projection is in meters)
Map units per bar unit : if you want to display in km, then you'd put
a bar unit at 1000 (5000/1000 = 5km).
In short, you need to adjust the above parameters to suit the
size/scale of the area you're creating a map for.
On Thu, Oct 25, 2012 at 2:31 AM, michael chiverton <qgislist at gmail.com> wrote:
> Hi All,
> Why is it that sometimes when i add a scale bar to my maps in the map
> composer it indicates a 0. How do i assure this does not happen is it
> somthing in the qguis map field or is it an issue with the composer?
> thanks,
> Mike
> Qgis-user mailing list
