[Qgis-user] SQLite plugin
Noli Sicad
nsicad at gmail.com
Thu Oct 25 04:50:49 PDT 2012
Hi Tyler,
You need to install pyspatialite.
Find out first the version of your spatialtite and follow the
instruction on how to install pyspatilate here.
http://www.gaia-gis.it/spatialite-3.0.0-BETA/spatialite-cookbook/html/python.html
Noli
On 10/25/12, Frazier, Tyler James <tyler.j.frazier at tu-berlin.de> wrote:
> Hi, I was trying to load a QGIS layer into SQLite using the SQLite plugin
> and get the following error -- not sure what to do? Any suggestions?
> thanks! Ty
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File
> "/Users/tyfrazier/.qgis//python/plugins/QspatiaLite/QspatiaLiteApp.py", line
> 358, in importTxt
> self.app=ImportTxt(self)
> File
> "/Users/tyfrazier/.qgis//python/plugins/QspatiaLite/importTxt/importTxt.py",
> line 30, in __init__
> self.ui.charsetList_CSV.insertItems(0, self.charset)
> TypeError: QComboBox.insertItems(int, QStringList): argument 2 has
> unexpected type 'list'
> Python version:
> 2.7.1 (r271:86832, Jul 31 2011, 19:30:53)
> [GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)]
> QGIS version:
> 1.8.0-Lisboa Lisboa,
> Python path: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python',
> '/Users/tyfrazier/.qgis//python', '/Users/tyfrazier/.qgis//python/plugins',
> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
> '/Library/Frameworks/SQLite3.framework/Versions/3/Python/2.7',
> '/Library/Python/2.7/site-packages/numpy-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.9/Python/2.7/site-packages',
> '/Library/Frameworks/cairo.framework/Versions/1/Python/2.7',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
> '/Library/Python/2.7/site-packages',
> '/Library/Python/2.7/site-packages/PIL',
> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools',
> '/Users/tyfrazier/Documents/workspace/frazier/simpop_accra/mapping/qgis_project']
> Tyler Frazier
> Department of Transportation Planning and Telematics
> Technical University Berlin
> http://www.vsp.tu-berlin.de/
