[Qgis-user] ubuntu 12.10 issues
Alex Mandel tech_dev at wildintellect.com
Sun Oct 28 17:00:15 PDT 2012
I had a similar issue on my upgrade to 12.04 and my issues were due to
newer packages (not qgis) being pulled from either upstream ubuntu or
3rd party repos. After carefully making sure ubuntu proposed and
backports were off and disabling all 3rd party I forced a downgrade to
stock ubuntu packages. Once I did that turning qgis repos back on worked.
Enjoy,
Alex
On 10/28/2012 03:06 PM, Simon Cropper wrote:
> On 29/10/12 07:45, Nick Kendall wrote:
>> Thanks! I'll try it
>> Sent from my mobile device
>> On Oct 28, 2012, at 10:09 AM, Etienne Tourigny
>> <etourigny.dev at gmail.com> wrote:
>>> also make sure you have no packages containing qgis.
>>> This is easy to do with synaptic:
>>> - add qgis filter
>>> - sort by installed (the first column)
>>> On 10/28/12, Goyo <goyodiaz at gmail.com> wrote:
>>>> 2012/10/27 Nicholas Efremov-Kendall <n.e.kendall at gmail.com>:
>>>>>         Depends: qgis-common (= 1.8.0-1~quantal1) but
>>>>> 1.9.0+git20121015+5afd739~precise-ubuntugis1 is to be installed
>>>> - Uninstall qgis-common if it's still installed (I think that's the
>>>> case).
>>>> - Make sure you don't have http://qgis.org/ubuntugis-nightly/ in any
>>>> of your sources lists (it seems like you don't have it any more but
>>>> check).
>>>> - Try again.
>>>> Goyo
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Hi,
> I'll join in here as I am having possibly related issues.
> Since upgrading to 12.10 I have not been able to get QGIS to work.
> It appears as if the repositories are not configured to install the
> correct dependencies.
> This is the error/message synaptic throws when I try and install...
> qgis:
>  Depends: qgis-providers but it is not going to be installed
>  Depends: qgis-common but it is not going to be installed
>  Recommends: qgis-plugin-grass but it is not going to be installed
> I have tried setting sources to the nightly builds but it just baulks;
> again complaining about dependencies.
> Is quantal builds packages differently than previous versions?
