[Qgis-user] 1.7.4 "Wroclaw" Vs 1.8.0 "Lisboa" on OSX 10.6.8
simbamangu simbamangu+osgeo at gmail.com
Mon Oct 29 22:57:07 PDT 2012
Actually the title of that blog post should probably read "fixing issues
AFTER reinstalling QGIS" ... I seem to have left out that part.
So:
1. Reinstall QGIS - delete the original, and replace with the new version
(which can be either an upgrade or the same one as before);
2. Remove the directories suggested in the blog post.
Using the terminal - after opening it, copy and paste each of the following
lines into the terminal and press enter - these are 'remove' (rm) commands,
that delete the files or groups of files indicated. For example, the first
line removes all the files beginning with "org.qgis." inside the directory
/Users/[USERNAME]/Caches/ - where [USERNAME] is your local name on the
computer.
rm ~/Library/Caches/org.qgis.*
rm ~/Library/Preferences/org.qgis.*
rm ~/Library/Saved\ Application\ State/org.qgis.*
rm -r ~/.qgis/
If you get a "no such file or directory" for some of these, that's OK.
View this message in context: http://osgeo-org.1560.n6.nabble.com/1-7-4-Wroclaw-Vs-1-8-0-Lisboa-on-OSX-10-6-8-tp5011868p5012137.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
