[Qgis-user] "Normal" mdb support possible for "normal" people?
Even Rouault
even.rouault at mines-paris.org
Sun Sep 23 13:15:06 PDT 2012
Le dimanche 23 septembre 2012 21:58:30, Etienne Tourigny a écrit :
> Hi Even,
> can you comment on using the java jackcess library? It's probably the
> only cross-platform solution. Does it support normal mdb files, and if
> not, can it benefit from your recent additions?
> http://www.gdal.org/ogr/drv_mdb.html
> http://jackcess.sourceforge.net/
The MDB driver (with Jackcess library) indeed already supports normal MDB
files. But it is a bit of a pain to use (needs linking GDAL with a JVM and the
Jackess .jar), so the latest improvement to the ODBC driver should make it
easier.
