[Qgis-user] Qgis web client resize map issue
mirko mirko.lavalle78 at gmail.com
Tue Apr 2 03:44:19 PDT 2013
who as me has problems with map panel resize in qgis web client when right
panel (attribute panel) has been opened can try following code. I have not
tested it with all browsers but it should work.
I don't know if it has been fixed in last release. If not this is what i
have done in an old version:
1. Css modify: add the following:
   #geoExtMapPanel { width: 100%; height: 100%; }
   #geoExtMapPanel .x-panel-bwrap { height: 100%; }
   #geoExtMapPanel .olMap { height: 100%; overflow: hidden; display: block;
   #geoExtMapPanel .olMapViewport { height: 100%; display: block; }
2. Make a backup of WebgisInit.js. Modify some code into WebgisInit.js:
  find this line: "geoExtMap" map object ( geoExtMap = new GeoExt.MapPanel
  Comment following lines:
      width: MapPanelRef.getInnerWidth(),
      height: MapPanelRef.getInnerHeight(),
  Add following lines:
      layout: 'fit',
      width: '100%',
      height: '100%',
      flex: 1,
3. Make a backup of GUI.js. Modify some code into GUI.js:
    - find this: id: "CenterPanel";
    - If not present add following line:
       *   flex: 1,
    - find this line: id: 'MapPanel',
    - if not present add following lines:
       *   layout: 'fit',
       *   flex: 1,
I hope this can be useful to someone.
Regards
Mirko
View this message in context: http://osgeo-org.1560.n6.nabble.com/Qgis-web-client-resize-map-issue-tp5044037.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
