[Qgis-user] Sextante - installation error
José Pedro Santos
zpsantos1 at hotmail.com
Mon Apr 29 01:53:32 PDT 2013
Hi Marco,
In my Linux distribution works very well (Ubuntu - Debian). Do you have the permissions to install plugins? If you install another one it works fine?
Check if Python is install correctly or exist in your computer write on the terminal: which python
If is not install you make it with the Synaptic package.
I hope I had helped.
Regards,
José Santos
To: qgis-user at lists.osgeo.org
Date: Fri, 26 Apr 2013 12:52:38 +0000
Subject: [Qgis-user] Sextante - installation error
Hallo
Maybe I didnt give enough infomations for solving my problem. Therefore I try it again.
The problem is as follows: I would like to use the sextante plugin in qgis on linux debian. I did allready download it on windows and there it works fine. But Im still not able to do so on linux.
I attached the error report I get when I try to install the plugin.
After quitting the error report it says:
The plugin is broken. Python said:
'module' object has no attribute 'NullFID'
I hope there is somone who knows whats to do, im pretty new to qgis but and python so would be greatefull if someone could help me.
Thanks
Marco
________________________________________
Von: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org]" im Auftrag von "Cortesi Marco [macortes at student.ethz.ch]
Gesendet: Donnerstag, 25. April 2013 14:49
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Problem: Sextante installation unsuccessfull
Hi
I'm new to this mailing list. I do have a problem with installing the sextante plugin. I allways get the message:
Diese Erweiterung ist defekt. Python meldete:
Does anyone know what's wrong?
Thanks a lot
Marco
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130429/d38d225e/attachment.html>
