[Qgis-user] transparency for QGIS backgroud color
Raymond Nijssen
r.nijssen at terglobo.nl
Mon Aug 5 12:51:12 PDT 2013
Thanks Nathan!
That is exactly what I was looking for. Didn't know it was there, in the
composer.
Raymond
On 04-08-13 13:53, Nathan Woodrow wrote:
> >> Unfortunately this is not possible. I could use this as well,
> making it possible to put two map-items on top of each other in a
> composer.
> The composer map view already support alpha for background colour in 2.0
> http://i.imgur.com/MoTOVLd.png
> Alpha in the main QGIS map window background colour isn't supported yet.
> - Nathan
> On Sun, Aug 4, 2013 at 9:18 PM, Raymond Nijssen <r.nijssen at terglobo.nl
> <mailto:r.nijssen at terglobo.nl>> wrote:
> Hi Otto,
> composer.
> Currently, in the options dialog, the "select color" (yellow) has
> a color-dialog containing the alpha channel. The "background
> color" has a dialog without it.
> Raymond
> On 31-07-13 17:52, Otto Dassau wrote:
> Hi,
> is it possible to set the background color in QGIS
> transparent. Can it be
> done in settings - project properties - backgroud color?
> Thanks
> Otto
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Terglobo
> Ampèrestraat 110
> 5223 CT 's-Hertogenbosch
> 06-25314983
Terglobo
Ampèrestraat 110
06-25314983
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130805/45113065/attachment.html>
