[Qgis-user] combine field calculator functions
Alexandre Neto
senhor.neto at gmail.com
Tue Aug 6 07:53:06 PDT 2013
Hello Michael,
If all you want is to be able to display 6 categories with diferent colors,
isn't rule-based symbology an option for you? You can agregate several
values in each category using simple operators, and this way you don't even
need to create a new column in your data.
Hope it helps,
Alexandre Neto
On Tue, Aug 6, 2013 at 3:11 PM, Michael Giebels <giebels at meo-carbon.com>wrote:
> Hi Carlos,
> thanks for your input. I tried this before. However I am not able to open
> *.dbf tables in Excel. It appears not to be readable in a suitable form
> (Yes, I do go the way over right click, show all files, open, and define
> seperators etc.). Somehow Excel does not read the row break properly (when
> I try to import the pure data without the header it tries to show all data
> in the first row and aborts due to limited number of columns in Excel). I
> tried different file origins (MacIntosh, Windows, DOS) as well. In a German
> forum I found information that Microsoft does not support *.dbf files
> anymore for Excel 2010 or higher which might explain that issue.
> Btw: I am running QGIS 1.8 on a Mac OS X Version 10.7.5 (whom ever this
> information helps) with MS Excel for Mac2011 Version 14.3.6 on it.
> I mentioned it before to Nathan already. All I want to do in the end is to
> convert six categories so I can display them in differing colors without
> creating new layers. But that is the way I have to do it in the end I
> guess.
> Thanks for your replies and thanks for having me in the community
> Michael
> Am 06.08.13 15:24, schrieb Carlos Cerdán:
> ... or perhaps you can:
> 0. Add the new column, acording type od data and length and... save and
> close QGIS (no data added).
> 1. Open the *.DBF table with LibreOffice Calc or MS Excel, to take
> advantage of their functions
> 2. Calc-Excel formulas would be taken as text, so you have to overwrite
> them with their own results
> 3. Save (as *.DBF).
> 4. Open the shape in QGIS. It will have the new data.
> 5. An "advanced" step 2 is add new columns directly in Calc/Excel. For
> that, watch the headers: they have: name_of_camp , type_of_data , lenght
> Good luck
> Carlos Cerdán
> 2013/8/6 Nathan Woodrow <madmanwoo at gmail.com>
>> Hey Micheal,
>> This is currently not possible. If you are running QGIS 1.9 you do
>> have the ability to define your own functions using Python example here
>> https://github.com/NathanW2/qgsexpressionsplus/blob/master/functions.py however
>> if you are new to Python and QGIS this isn't something I would do right
>> away.
>> - Nathan
>> On Tue, Aug 6, 2013 at 9:38 PM, Michael Giebels <giebels at meo-carbon.com>wrote:
>>> Hello QGIS users,
>>> the QGIS world is new to me, so please be gentle...
>>> I am wondering how I could combine field calculator functions in order
>>> to convert information from an existing data column into a new one.
>>> What I can do with my mediocre knowledge is to query information from
>>> column 1 by setting
>>> "column1"='abc'
>>> which gives me a binary result (0,1) in my resulting column. Then I can
>>> replace ("newcolumn",'1','6')
>>> How could I combine these two into one working function (i.e. there MUST
>>> be a simple expression in the function list) and do not lose the new number
>>> when querying another information (e.g. 'cba') from column 1?
>>> Thanks in advance!
>>> Michael
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130806/aa7874ab/attachment.html>
