[Qgis-user] WMTS
Bruce, Bob (CWS)
Bob.Bruce at gov.mb.ca
Tue Aug 6 16:01:51 PDT 2013
Thanks everyone for your input on this. The solution for this is to add the strings &SERVICE=WMTS&REQUEST=GetCapabilites to the URL for the WMTS.
This seems to 'tell' QGIS to use WMTS instead of WMS.
This only worked for me in the latest master (1.9.0-354) version of QGIS.
Bob Bruce
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Bruce, Bob (CWS)
Sent: August-02-13 2:59 PM
To: 'Andreas Neumann'; 'Jonathan Moules'
Cc: 'qgis-user at lists.osgeo.org'; 'ekeighan at cubewerx.com'
Subject: Re: [Qgis-user] WMTS
Andreas,
I have a WMTS connection to try:
http://nis.cubewerx.com/cubewerx/cubeserv?CONFIG=OIM_MB_-_Orthophoto-WMTS
this is an OGC compliant WMTS server.
(the GetCapabilities request is at: http://nis.cubewerx.com/cubewerx/cubeserv?CONFIG=OIM_MB_-_Orthophoto-WMTS&SERVICE=WMTS&REQUEST=GetCapabilities )
this is part of our NIS pilot project and will be available for another 3 months.
Unfortunately I have not been able to get this to work with either the stable version of QGIS 1.8.0 or the current development version of 1.9.
I am able to get this WMTS server to work with OpenLayers though through a web page that I have created.
Do you know how QGIS detects that this is a WMTS connection since we are using the WMS connection dialog? I am seeing error messages that keep saying that a WMS connection could not be established, is that because the error message is currently not specific to the type of connection (WMS or WMTS) or because it didn't try and make a WMTS connection?
Thanks,
Bob Bruce
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: August-02-13 7:12 AM
To: Jonathan Moules
Cc: qgis-user at lists.osgeo.org
Hi Jonathan,
Perhaps it would make sense to go the extra mile and either test another Geoserver WMTS or make your WMTS server publically available (at least in a password protected manner) - so that people can test it.
Although WMTS is standardized there are often minor issues that prevent particular implementations from working. I know that WMTS is working in general. I was able to test it against an Intergraph-based WMTS server - but I do not have a Geoserver instance at hand.
Andreas
On Fri, 2 Aug 2013 12:29:18 +0100, Jonathan Moules wrote:
> Hi Andreas,
> Yep, it's a local URL; that hostname is on our local DNS for our
> mapping systems. The URL is correct; it works fine in ArcMap as noted.
> My QGIS cannot connect to the internet so I can't test with external
> datasets; QGIS's proxy setup doesn't like our proxy.
> I held off reporting as a bug because I didn't know if I was doing
> something wrong and there's no error.
> Can other folks connect to a GeoServer WMTS?
> Thanks,
> Jonathan
> On 2 August 2013 12:25, Andreas Neumann wrote:
>> Hi Jonathan,
>> Are you sure that the URL is correct? It seems that this server is
>> only available locally. At least it is not a publically available and
>> correct URL.
>> If you think there is a bug in QGIS, please write a bug report and
>> provide a test URL.
>> Andreas
>> On Fri, 2 Aug 2013 11:51:55 +0100, Jonathan Moules wrote:
>>> Thanks Andreas;
>>> I'd suggest changing the following text:
>>> - Tooltip
>>> - dialog header
>>> - Help (may be changed, but my help doesn't load right now!)
>>> Beyond that, it doesn't seem to work. I add my connection
>>> (http://compass/geoserver/gwc/service/wmts [8] [8]), and then when I
>>> click
>>> "connect" it swaps to the "server search" tab. But there's nothing
>>> listed. I didn't tick any of the boxes.
>>> GeoServer 2.3.4 WMTS.
>>> ArcMap can connect to it, so I know it's not a problem with the
>>> WMTS.
>>> How do I get it to work?
>>> It does connect to my WMS fine.
>>> Thanks,
>>> Jonathan
>>> On 2 August 2013 10:52, Andreas Neumann wrote:
>>>> And this is already fixed in Master - see
>>>> http://hub.qgis.org/issues/8396 [5] [5] - thanks to Jürgen.
>>>> Andreas
>>>> On Fri, 02 Aug 2013 11:29:39 +0200, Andreas Neumann wrote:
>>>>> Hi Jonathan,
>>>>> You just use the WMS connection dialogue. It also works for WMTS.
>>>>> I am now opening a bug to change the "Add WMS layer" into "Add
>>>>> WMS/WMTS layer". This should make things clearer to the users.
>>>>> Andreas
>>>>> On Thu, 1 Aug 2013 11:42:50 +0100, Jonathan Moules wrote:
>>>>>> Hi List,
>>>>>> How do I use WMTS in QGIS (weekly build)?
>>>>>> I've tried searches on:
>>>>>> * qgis.org [1] [1] [1] - no results
>>>>>> * wiki - no results
>>>>>> http://docs.qgis.org/2.0/html/en/docs/user_manual [2] [2] [2] -
>>>>>> one
>>>>>> results
>>>>>> about caches.
>>>>>> * plugs.qgis - no results
>>>>>> Thanks,
>>>>>> Jonathan
>>>>>> This transmission is intended for the named addressee(s) only
>>>>>> and may contain sensitive or protectively marked material up to
>>>>>> RESTRICTED and should be handled accordingly. Unless you are the
>>>>>> named addressee (or authorised to receive it for the addressee)
>>>>>> you may not copy or use it, or disclose it to anyone else. If you
>>>>>> have received this transmission in error please notify the sender
>>>>>> immediately.
>>>>>> All
>>>>>> email
>>>>>> traffic sent to or from us, including without limitation all GCSX
>>>>>> traffic, may be subject to recording and/or monitoring in
>>>>>> accordance with relevant legislation.
>>>>>> Links:
>>>>>> [1] http://qgis.org [3] [3]
>>>>>> [2] http://docs.qgis.org/2.0/html/en/docs/user_manual [4] [4]
>>>> Andreas Neumann
>>>> Böschacherstrasse 10A
>>>> 8624 Grüt (Gossau ZH)
>>>> Switzerland
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org [6] [6]
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user [7] [7]
>>> This transmission is intended for the named addressee(s) only and
>>> named addressee (or authorised to receive it for the addressee) you
>>> may not copy or use it, or disclose it to anyone else. If you have
>>> immediately. All email traffic sent to or from us, including without
>>> limitation all GCSX traffic, may be subject to recording and/or
>>> monitoring in accordance with relevant legislation.
>>> Links:
>>> [1] http://qgis.org [9]
>>> [2] http://docs.qgis.org/2.0/html/en/docs/user_manual [10] [3]
>>> http://qgis.org [11] [4]
>>> http://docs.qgis.org/2.0/html/en/docs/user_manual [12] [5]
>>> http://hub.qgis.org/issues/8396 [13] [6]
>>> mailto:Qgis-user at lists.osgeo.org [14] [7]
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user [15] [8]
>>> http://compass/geoserver/gwc/service/wmts [16] [9]
>>> mailto:a.neumann at carto.net [17]
>> Andreas Neumann
>> Switzerland
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic, may be subject to recording and/or monitoring in accordance
> Links:
> [1] http://qgis.org
> [3] http://qgis.org
> [4] http://docs.qgis.org/2.0/html/en/docs/user_manual
> [5] http://hub.qgis.org/issues/8396
> [6] mailto:Qgis-user at lists.osgeo.org
> [7] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [8] http://compass/geoserver/gwc/service/wmts
> [9] http://qgis.org
> [10] http://docs.qgis.org/2.0/html/en/docs/user_manual
> [11] http://qgis.org
> [12] http://docs.qgis.org/2.0/html/en/docs/user_manual
> [13] http://hub.qgis.org/issues/8396
> [14] mailto:Qgis-user at lists.osgeo.org
> [15] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [16] http://compass/geoserver/gwc/service/wmts
> [17] mailto:a.neumann at carto.net
> [18] mailto:a.neumann at carto.net
Andreas Neumann
Switzerland
