[Qgis-user] WMTS
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Aug 7 03:58:12 PDT 2013
Is this something that should be documented though? That suggests this is
desired behaviour.
As a user I'd expect QGIS to:
a) Figure it out automatically.
or
b) Have a separate button for WMTS.
Requiring a user to add stuff to the URL is very suboptimal.
Jonathan
On 7 August 2013 06:09, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 07/08/2013 01:01, Bruce, Bob (CWS) ha scritto:
> > Thanks everyone for your input on this. The solution for this is to
> > add the strings &SERVICE=WMTS&REQUEST=GetCapabilites to the URL for
> > the WMTS.
> > This seems to 'tell' QGIS to use WMTS instead of WMS.
> Hi Bob,
> could you please check that this is correctly documented in the new
> manual?
> Thanks.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.14 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlIB1o8ACgkQ/NedwLUzIr4VKwCgq2k0CX/OODYxD6z9XMB7Vwad
> gTMAoJiWfcGD3sMTUoq8uIiSwnPrxGUz
> =0y/E
> -----END PGP SIGNATURE-----
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130807/767cdd01/attachment.html>
