[Qgis-user] Feature Subset query builder
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Aug 8 03:04:23 PDT 2013
Hi Regis,
   It's a SpatiaLite database. I just tested this in a couple of SQLite
clients and they both exhibit the same behaviour, so I guess it's an SQLite
issue. Weird.
Thanks,
Jonathan
On 8 August 2013 10:31, Régis Haubourg
<regis.haubourg at eau-adour-garonne.fr>wrote:
> Hi,
> what is the datasource you are testing? shp, postgres?
> http://osgeo-org.1560.x6.nabble.com/Feature-Subset-query-builder-tp5071434p5071443.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130808/80f3ffc8/attachment.html>
