[Qgis-user] [Qgis-developer] [BUG?] Not possible to edit raster layer title in legend
Ramon AndiƱach
custard at westnet.com.au
Thu Aug 8 03:57:21 PDT 2013
Hmm. Had a sporadic the other day with a vector rather than a raster. I'd change the title and the print composer repeatedly ignored the change.
I dumped the layer from the legend then added it back in and everything worked as expected.
That might at least help as a work around.
-ramon.
On 08/08/2013, at 18:02, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Using QGIS 1.9 d821bcc, in windows 7 64bits, I'm not able to change the title of raster layers in the legend using legend item properties tab.
> I have no problems changing the title when working with vector layers.
> Can anyone confirm this? I'm pretty sure I have done this before.
> Is there a ticket for it?
> Best regards,
> Alexandre Neto
> Qgis-developer mailing list
