[Qgis-user] Spatial Join
Randal Hale
rjhale at northrivergeographic.com
Thu Aug 8 05:12:52 PDT 2013
Here's how I would do it: You have Two polygon layers and you need to
count the number of polygons in layer 1 that are contained in the
polygons in layer 2
1. Convert the polygons in 1 to points: Vector -> geometry -> polygon
centroids
2. then use -> vector -> analysis tools -> points in polygon. Count the
number of points contained by polygons in layer 2.
Hope that helps or at least creates an idea.
Randy
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
<mailto:rjhale at northrivergeographic.com>
twitter:rjhale
http://about.me/rjhale
On 08/08/2013 07:36 AM, Jonathan Moules wrote:
> Hi List,
> I have two layers of polygons. I want to do some analysis between
> them, basically doing a spatial join, counting how many of one polygon
> layer there are intersecting with each polygon in the other layer.
> ArcGIS does this easily with the "Spatial Join" tool (ArcToolbox
> version). How can I do this in QGIS?
> I know there is Vector -> Data Manage Tools -> Join attributes by
> location, but that only acts as a basic join and doesn't allow for
> counting of the number of joins.
> Sextante has a large collection of tools, but none of them seem to
> have any help so I don't know what any of them do. (And none of them
> seem applicable anyway).
> Suggestions welcome, Cheers,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130808/84e7f658/attachment.html>
