[Qgis-user] Message: Can not make qgis.db private copy
lewie
lewie.dekker at gmail.com
Fri Aug 9 20:56:07 PDT 2013
In case you haven solved it already, it is caused by the installer creating
the .qgis2 folder as root so your local account can store the qgis
configuration files etc (messes up sextante too). Had the same problem just
now (Aug 8) on fresh install of nightly build!
Just chown the directory and the gdal_pam folder contained therein, or
remove .qgis2 altogether and recreate it as your regular user. Now restart
qgis and you should be fine.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Message-Can-not-make-qgis-db-private-copy-tp5064236p5071817.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
