[Qgis-user] "Resetting " toolboxes
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Mon Aug 12 04:00:03 PDT 2013
If the toolbar is disappearing when it shouldn't be (what I read from your
message), that sounds like a bug. If you report all the
circumstances/details about it here -
http://hub.qgis.org/projects/quantum-gis/issues - along with screenshots,
that'll hopefully let someone replicate and fix it.
Jonathan
On 11 August 2013 15:59, Lene Fischer <lfi at life.ku.dk> wrote:
> Hi
> If a toolbox is moves in a new position it sometimes disapear. With a
> rightclick I try to turn it off/on. But with no succes.
> Then I can use the REGEDIT HKEY_CURRENT_USER\Software\QuantumGIS\QGIS\UI
> to delete.
> But this is not a solution for users.
> Is there another/easy solution?
> Regards
> Lene Fischer
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/851ad681/attachment.html>
