[Qgis-user] Label using $area and decimals Master 31
    Jonathan Moules
    jonathanmoules at warwickshire.gov.uk
    Mon Aug 12 04:02:37 PDT 2013
Possibly this? http://hub.qgis.org/issues/8405  - it was fixed a few days
ago apparently so if it is still happening in a new build it sounds like a
different bug.
Also maybe - http://hub.qgis.org/issues/5546 - unfixed.
Jonathan
On 11 August 2013 16:31, Lene Fischer <lfi at life.ku.dk> wrote:
>  Hi Larry
> The decimal funcion works fine -  if I only choose the $area function.
> But when I add another field or 'text' the number of decimals expand.
> Regards
> Lene Fischer
> *Fra:* larry at shafferinteractive.com [larry at shafferinteractive.com] på
> vegne af Larry Shaffer [larrys at dakotacarto.com]
> *Sendt:* 8. august 2013 05:56
> *Til:* Lene Fischer
> *Cc:* qgis-user at lists.osgeo.org
> *Emne:* Re: [Qgis-user] Label using $area and decimals
>   Hi Lene,
> On Wed, Aug 7, 2013 at 9:09 PM, Lene Fischer <lfi at life.ku.dk> wrote:
>>   Hello
>> In Master I´m trying to set a label with the function $area. This works
>> fine.
>> But I´m trying to use the formatting for numbers with only 1 decimal -
>>  no succes.
>  Hmm. I just tried setting the expression to $area and using the
> 'Formatted numbers' option for the layer: worked. I also used just an
> expression:
> format_number( $area, 3)
>  and that worked too, even where the area result was a whole integer,
> i.e. label was 12.000. I tested with precision of '1' and both worked fine.
> Can you share the data, even if it is just a file containing the individual
> feature that is not labeling properly?
>>   It works fine if I use a coloumn containing the area.
>    But this is not a solution because the $area is not dynamic in the
>> coloum of the attribut table.
>>  Secondly - how do I activate the functions in the Labeltoolbar -ex Move
>> or Show/Hide
>  New documentation for labeling canvas map tools is forthcoming. For now,
> you can reference:
> http://gis.stackexchange.com/questions/67408
>  Regards,
>  Larry
>>   Regards
>>  Lene Fischer
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/dd368a61/attachment.html>
