[Qgis-user] I could not run Qgis
Yasser Said Lopez de Olmos Reyes
biolyasser at gmail.com
Mon Aug 12 13:13:47 PDT 2013
Hi
The nircmd.exe error is a known one, but it's not related directly with
QGIS but sometimes with malware, registry errors or corrupted files. I
would start trying to repair errors in registry using maybe CCleaner from
Piriform or some similar software (a Registry fixer). If that won't solve
the problem, run anti-malware software.
Using other kind of installation may be a workaround, OSGEO4W for instance.
2013/8/12 José Pedro Santos <zpsantos1 at hotmail.com>
> Hi,
> Are you using the standalone installer or the OSGeo4w Installer? If is the
> second one, delete the folders related with qgis, sextante... and then try
> again.
> Good Luck,
> José Santos
> From: ted at icddrb.org
> To: madmanwoo at gmail.com; goyodiaz at gmail.com
> Date: Mon, 12 Aug 2013 09:41:03 +0000
> CC: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] I could not run Qgis
> I have down loaded but could not run QGIS. Please help.
> *From:* Nathan Woodrow [mailto:madmanwoo at gmail.com]
> *Sent:* Monday, August 12, 2013 3:33 PM
> *To:* Goyo
> *Cc:* Dr. Md. Manirul Islam; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] I could not run Qgis
> On Mon, Aug 12, 2013 at 7:28 PM, Goyo <goyodiaz at gmail.com> wrote:
> I'm unable to tell what's going on in your case but nircmd.exe is not
> needed to run QGIS.
> Yes nircmd is used to run QGIS without showing the command window that
> setups up that paths.
> - Nathan
> _______________________________________________ Qgis-user mailing list
Saludos,
Yasser
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/200c7d7f/attachment.html>
