[Qgis-user] Consultation
Carlos Cerdán
sig.upagu at gmail.com
Wed Aug 14 20:09:24 PDT 2013
Hi Teresa
Just open the 1.7 version project whit 1.8 version, there would isn't
problem to do it.... or What issue do you have? Is There some error
message? Layers are in the same directory path?
Simplemente abre el proyecto de la versión 1.7 con la versión 1.8, no
debería haber problema para ello... ¿o tienes algún problema? ¿Hay algún
mensaje de error? ¿Las capas siguen en la misma ruta de directorios?
Carlos Cerdán
(Cajamarca - Perú)
2013/8/14 Teresa Arias <tarias001 at gmail.com>
> I'm speaking Spanish, sorry but need to know:
> How to read a draft version 1.7, in version 1.8?
> 2013/8/14 <qgis-user-request at lists.osgeo.org>
>> Send Qgis-user mailing list submissions to
>> qgis-user at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> qgis-user-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of Qgis-user digest..."
>> Today's Topics:
>> 1. Map doesn't appear in the Composer (Annisa Indah Sari)
>> 2. Re: Map doesn't appear in the Composer (Stott James)
>> 3. Search in fields plugin (Alexandre Neto)
>> Message: 1
>> Date: Wed, 14 Aug 2013 04:54:59 +0200
>> From: Annisa Indah Sari <annisaindah at hotmail.com>
>> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
>> Subject: [Qgis-user] Map doesn't appear in the Composer
>> Message-ID: <DUB125-W56E55B2CE07B9A62104D72BF450 at phx.gbl>
>> Content-Type: text/plain; charset="iso-8859-1"
>> Hi QGIS users,
>> I use QGIS 1.8 and not a new user but just met this situation below:
>> My map doesn't appear in the Composer after I clicked "Add New Map". I
>> checked the scale, the map projection, and the data frame projection are
>> all correct. I have been trying to check and uncheck the "Control rendering
>> order" and "render". And also check the map scale in the composer. All are
>> correct. But why does the map still not appear?
>> Thanks.
>> Annisa
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130814/68c22472/attachment-0001.html
>> Message: 2
>> Date: Wed, 14 Aug 2013 05:46:37 +0000
>> From: Stott James <fmrojst at fylkesmannen.no>
>> Subject: Re: [Qgis-user] Map doesn't appear in the Composer
>> Message-ID:
>> <FA49BFC197A78E4D8E7F1200278E5F555B13791A at fmexch1.fylkesmannen.local>
>> Apologies if you have tried this already but you don't mention it, but
>> did you click the 'Set to map canvas extent' button?
>> Fra: qgis-user-bounces at lists.osgeo.org [mailto:
>> qgis-user-bounces at lists.osgeo.org] P? vegne av Annisa Indah Sari
>> Sendt: 14. august 2013 04:55
>> Til: qgis-user at lists.osgeo.org
>> Emne: [Qgis-user] Map doesn't appear in the Composer
>> Hi QGIS users,
>> Thanks.
>> Annisa
>> URL: <
>> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130814/8eff3637/attachment-0001.html
>> Message: 3
>> Date: Wed, 14 Aug 2013 11:24:30 +0100
>> From: Alexandre Neto <senhor.neto at gmail.com>
>> To: QGIS User <qgis-user at lists.osgeo.org>
>> Subject: [Qgis-user] Search in fields plugin
>> Message-ID:
>> <CA+H0G_GEF_VwR_8dJgJpYnBL-6M3M6ouQEjqLcaA5mAT=
>> DqG6g at mail.gmail.com>
>> Does anyone know of the existence of a plugin that allows one to easily
>> search for a string or specific value in one or more layer in a project?
>> Something like the OSMSearch but for the project layers.
>> Thanks,
>> Alexandre Neto
>> URL: <
>> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130814/c9634c45/attachment-0001.html
>> End of Qgis-user Digest, Vol 90, Issue 40
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130814/1db5586a/attachment.html>
