[Qgis-user] Labels window goes out the visible area of monitor
    Nathan Woodrow
    madmanwoo at gmail.com
    Thu Aug 15 07:08:27 PDT 2013
or you can use the Modulo operator ;)
CASE WHEN Z_msnm % 400 = 0 THEN Z_msnm END
- Nathan
On Fri, Aug 16, 2013 at 12:04 AM, Carlos Cerdán <sig.upagu at gmail.com> wrote:
> Hi dear group
> I have a topographic layer that I want to put labels when the contour is
> multiplo of 200. I got it with this large conditional sentence:
> case
> when ("Z_msnm" =200 OR "Z_msnm" =400 OR "Z_msnm" =600 OR "Z_msnm" =800 OR
> "Z_msnm" =1000 OR "Z_msnm" =1200 OR "Z_msnm" =1400 OR "Z_msnm" =1600 OR
> "Z_msnm" =1800 OR "Z_msnm" =2000 OR "Z_msnm" =2200 OR "Z_msnm" =2400 OR
> "Z_msnm" =2600 OR "Z_msnm" =2800 OR "Z_msnm" =3000 OR "Z_msnm" =3200 OR
> "Z_msnm" =3400 OR "Z_msnm" =3600 OR "Z_msnm" =3800 OR "Z_msnm" =4000 OR
> "Z_msnm" =4200 OR "Z_msnm" =4400 OR "Z_msnm" =4600 OR "Z_msnm" =4800 OR
> "Z_msnm" =5000 OR "Z_msnm" =5200 OR "Z_msnm" =5400 OR "Z_msnm" =5600 OR
> "Z_msnm" =5800 OR "Z_msnm" =6000 OR "Z_msnm" =6200 OR "Z_msnm" =6400 OR
> "Z_msnm" =6600 OR "Z_msnm" =6800) then "Z_msnm"
> end
> After to do this condition all was ok, but an issue appear: the "label
> layer configuration window" tries to show the condition in one line only,
> so the width of this window is so long that the right part of this window
> goes out of monitor visible area.
> Is there some way to avoid this?. It happens even if each condition is in
> diferent lines (QGIS 1.8 on Ubuntu 12.04 and Windows 7).
> Is there another smaller condition to use instead that the one I made?
> Thank you in advance for any help
> ------ 8< --- Spanish version ---
> Hola estimado grupo:
> Tengo una capa topográfica a la cual  deseo colocar etiquetas en las
> curvas de nivel múltiplo de 200. Esto lo hice con la condición mostrada
> arriba.
> case
> when ("Z_msnm ... etc
> end
> La condición trabaja bien, pero aparece un problema: la ventana de
> "configuración del etiquetado de la capa" muestra la condición en una sola
> línea, así que el ancho es tan grande que la parte derecha de esta ventana
> sale fuera del área  visible del monitor.
> ¿Existe alguna manera de evitar esto? Esto sucede inclusive si cada
> condición está en una línea diferente ( QGIS 1.8 en Ubuntu 12.04 y Windows
> 7).
>  ¿Hay alguna condición más corta que podría utilizar en lugar de la que
> hice?
> Gracias de antemano por cualquier ayuda
> ------ 8< -------
> Carlos Cerdán
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130816/6b4ed2b4/attachment.html>
