[Qgis-user] Oracle - QGIS connection
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Aug 16 06:35:35 PDT 2013
Hi List,
I'm having issues getting QGIS to connect to my native Oracle. I had it
working previously but have a new machine now and a new QGIS install so my
previous settings are gone.
I have SQL Developer installed which connects just fine with these:
Hostname: 10.76.112.33
> SID: gistest
However, if I try those in QGIS:
> Database: gistest
> Host: 10.76.112.33
I get this Oracle error instantly:
> ORA-12514 - TNS listener does not currently know fo the service requested
> in the connect descriptor.
If I change it to the TNS name, I get a different error:
> Database: gistest
> Host: co_gistest
After along time I get an Oracle error: ORA-12154 - TNS could nto resolve
the connect identifier specified.
I also get this error (but quicker) if the Host entered is the same as the
one in the TNSnames file.
Can anyone suggest what the problem is? SQLDeveloper and ArcGIS can both
direct connect to the database from this machine.
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130816/edc465c2/attachment.html>
