[Qgis-user] qgis api
Giuseppe Amatulli
giuseppe.amatulli at gmail.com
Mon Aug 19 12:08:27 PDT 2013
i'm trying to create a script that use qgis api to do an intersection
between two shp .
The script works fine in the Qgis python console returning "true" and
creating the intersect
shp, instead in the python console returns "false"
from qgis.core import *
from qgis import *
import qgis.utils
from qgis import analysis
from qgis.analysis import *
QgsApplication.initQgis()
shpA = QgsVectorLayer("/home/selv/tmp/for_clip.shp" , "layerA", "ogr")
shpB = QgsVectorLayer("/home/selv/tmp/bug5598.shp" , "layerB", "ogr")
QgsOverlayAnalyzer().intersection( shpA , shpB , "/home/selv/tmp/test.shp")
so after this lines i get
true in the qgis python console (the intersect shp is created)
false in the python console (the intersect shp is not created)
Should i load other modules? or do i missing something else?
Thanks
Regards
Giuseppe
Giuseppe Amatulli
Web: www.spatial-ecology.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130819/d2e746c9/attachment.html>
